Knock Sensor Help--please
Hello, 2002 5.3 avalanche. Had bad intake gaskets. Removed & Replaced with cheap plastic fel pro. Smoke tested and still bad. R&R with metal fel pro and replaced knock sensors (BWD) and harness (doorman). Torqued 18 or 15 ft lbs added silicone dam around knock sensors - half moon. Washed engine bay with light water from hose on shower modesince i made a mess. Got a knock sensor code - forgot which one but Passed smoke test. R&R everything with new stuff-same brands. Sealed all around knock sensor grommet and wire hole with gray gasket maker. Now P0332. WTF. Used multimeter at connector and ohm is 100.00 & other is 100.6. Niw no vac leaks but knock sensor problems. Before this no codes. I checked bafire starting any if this. Original Radiator knock s like new and firewall was a rust bucket. Ordered ac delco sensors and boxes looked like they were thrown around so I returned. Help please. If i do again it will be the 4th time.
I just did this on my 2001 tahoe last weekend. All new duralast everything from autozone. Put new ones in, got a bank 2 code. Replaced bank 2, bank one went out. Went to Autozone and told them to order the ACDelco and I would pay the difference of price. Replaced with acdelco and no code. Hope this helps. I got damn good at it now tho. I can R&R in a little over an hour now LOLOL. Hope this helps.
P.s. try to get OEM harness... I couldnt. Those cheap china knock sensors suck. Imo
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
