Doro Gasket Lubrication
My owner’s manual says to lubricate the door gaskets occasionally. Any ideas what to use? Dealer has “weatherstrip conditioner” but are asking a fortune. I can’t find any silicon lubricant at the autoparts store or at my home center. What is everybody else using?
i bought some dialectric grease from an online dealer. A tube was like $6. It is for weatherstripping
the part number is
12345579
I just finished with mine. I, too, bought the little tube of dielectric grease, and paid $14 at the stealer for it. I then went to Wal-Mart and bought a can of STP silicone lubricant. Cheap, it looks like a can of WD-40, but is is odorless, and doesn't feel too greasy when you touch it. Good stuff. The trick to it is you MUST lubricate both sides of the strippings, or you will get noise from them. If you have a truck, just pull them off, soak them, and then put them back on.
