285/70/17 - will it fit stock (no level/lift)?
Hi all,
Is anyone running a 285/70/17 tire with stock suspension(no level or lift)?
If not, what other tire sizes have fit the stock setup?
Thanks in advance - have not found anything specific in my searches ...
Great forum - lots of great info!
That's almost 34 inches. I'm going to be running exo grappler in that size next week but I'm going to have about 2.5 inches lift in front with bilstein and custom setup
You "searched" the most common question (will XXX/XX/XX fit) and got nothing?
Even google brings up specific results for that questions on our body style trucks...
Trik, he has 17's so those are just under a 33. That size in 18's is just under a 34.
Not sure if it will fit, that will be the same height I am going to go with but with a 1.5 level, I will also go skinnier (265/70/18). I have heard some people say they fit a 33ish stock but it really depends on what it is doing if it will rub. Levels are cheap (under $100) and you need an alignment after so to be sure I would just get a small level. Either way search, the answer is out there. You will get more info from many more people looking at varous threads then a few responses in one thread that may or may not be right, as the people who have done it might not respond because this question gets asked so often and they get tired of repeating themselves.
Tyler
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 676 Guests (See full list)
