Bed lighting and brakes?
Can anyone confirm for me that there cargo/under rail bed led lights go out while in reverse and while applying the brakes?? Just noticed this tonight while backing into the driveway? While in reverse, cargo switch on and applied the brakes the under bed rail lights go out??
Anyone else's truck do this as well?
Thanks.
My mirror lights and bed lights (even the outside cab light) go out when I put the truck in gear. They won't turn on while in drive or reverse
Yes im aware of this. And they all stay on when in reverse. Thats what they are intended for. I had the wrong harness plug for my year truck. All is is good now.
I used the supplied harness and plugged it into the place it specified and mine go out when I go into reverse, they work in neutral
Do you have the towing mirrors with led lights in them?? If so? They are supposed to stay on while in reverse. Thats what they are for. Trailer backup light assist. Its possible like mine. Your truck has 3 pins on the truck side of the plug?? This is where i had to make the change.
Yes, i havw the towing mirrors w/ the LED's. As soon as i hit reverse they go out
Sent from my SM-G935T using Tapatalk
Thats not right. The mirror lights should stay on while in reverse.
Hmm, interesting, my 2016 GMC 2500 did the same thing, went out as soon as I went into reverse
I just reseeded the plug and tried again, and now they stay on in reverse, interesting. . . thx
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,576 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
