Fuse Help Please
I am looking for 2 things.
First the fuse that controls the 2 cigarette lighter type plugs in the front and the usb ports beside them? i also want a tap in the fuse block that stays powered all the time.
I looked at the diagram on the panel cover and looked in the manual but could not find a clear answer. its become more of a "cant I rtfm"... now I have to have the answer of how the damn thing is wired. If i blew a fuse it would take me 4 days to figure out which one it was.
it looks like its fuse 1, 10, 11, 12, or even 49 on page 10-48 of the manual
2014 slt z71
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
