4L60e options
Are you doing it yourself?
Will you keep the vehicle for a long time?
Is cost a big factor?
Gm Good Wrench trans is the best but most expensive for the unit. :happysad:
Are you doing it yourself? YES
Will you keep the vehicle for a long time? YES
Is cost a big factor? YES - but not necessarily the only factor
Gm Good Wrench trans is the best but most expensive for the unit. :happysad:Would that be new one?
The Rebuild has 10k km on it apparently also. I requested confirmation of the rebuild (ie. receipts or shop contact info etc...)
I do plan to use the unit for towing at times also (garbage trailer, 16' flat deck occassionally).
I should add - a mechanic friend thinks the pump died internally on mine - pan was super hot - fluid hat burnt smell, but tranny cooler was cool to the touch.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
