Driver side Rear Brake creaking
Its been nicer here so I just noticed this sound. Everytime I push in my brake pedal I noticed a loud creaking sound coming from the driver side rear wheel. I even can hear it when the car is in park and I depress the brake pedal. Does anyone have any idea on what this could be? It's a 2015 Silverado LT and it currently has 53,000 miles. Any help would be greatly appreciated.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
