PC is gone
SnakeEyeSS
My keyboard went haywire, so did motherboard, and I need a new PC, don't know when I'll be back! on bro's computer, gotta run
wow sry to hear that. I know you can get some great deals now on new computers or even used fast systems so good luck on gettin one!
