Truck Hardware is GTG!
I ordered my Gatorback Mudflaps through Truck Hardware last year. Bought them off their website and they arrived in great shape. Easy instructions to follow and quality materials.
Last week I contacted them to try and get a replacement bracket for one of the mud flaps (due to my own issue, nothing to do with the quality of their product). I received a response within an hour or so, and was told they don't usually sell the pieces separately. The customer service rep contacted their manufacturer and was able to sell me just the bracket, and he pulled some strings and got it for a reduced price even. Received the product the next business day.
Great company to deal with and very nice, quality product!
Their website is https://www.truckhardware.ca
