I've spent quite some time researching lifts and level kits. I've decided to install a level kit that can be installed without cutting or drilling. At $306.99, seems to be a decent price. Haven't decided on rims and tires yet, still researching info. This is a "selectable" torsion bar key, that does not over stress the manufacturers limits on the torsion bars.....according to Suspension Maxx. At any rate, all the vendors seem to perform the same method of leveling. I'm not exceeding 2.5 inches of lift. I'd appreciate any review comments or info. Thanks. By the way, this is for a 2016 2500HD, crew cab, WT, 6.5 ft bed with stock 18" steel wheels.
save your money buy shock spacers and control arms and use the factory bars.
order you a set of differential spacers and be done with it. stress is stress raising is raising
its going to ride rougher just the say it is. control arms will keep you off the bump stops.
a lot of advertising that is no more than advertising on lots of these lifts. it will not ride like
stock cranking the bars no matter what method or product you use. now the bds kit
is another story.
I'm looking at the kit as well!
I like that it includes shock and diff spacers!
miker2702, is the BDS kit a "leveling kit"?
boynton6spd, I called Suspension Maxx today. I asked them If I raise the truck 2.5 inches, would a 34" tall, 11" wide tire rub, and the representative told me "no, it would not". I also asked if I needed to replace the upper control arms, in order to prevent rubbing, and his response was also "no". So.....I went further with soliciting questions regarding fitment. I asked him if I installed factory 18" aluminum alloys (eg have proper backspacing and offset), with Michelin LTX M/S2 295/70R/18, load range E, would there be any issues rubbing(?) And again, his response was "no". He mentioned that sticking to factory spec wheels was a lot easier, and a lot less problems. I'm trying to make good choices with this application. My truck is a daily long distance driver, so I kinda prefer a tire that I can get the most mileage. I rotate my tires and change my oil/oil filter every 5K miles. Yep, I've got OCD. Thanks for your comments!
Bds is the more expensive kit
Being offered. Should have a better than stock ride. There is a thread in last few days on here if some one putting one on.
There is a reason cognito sells
So many control arms. Once you tighten the bar suspension travel is limited. Not rubbing
Just doesn't mean tires. Frame stop and upper control arms
Can be annoying.search threads on here many discussions on the subject.
I gotcha' miker. I researched the 2-3" BDS coilover lift that eliminates the torsion bars all together. It looks very high tech, and at that price, it should be. I really do like it, I'm going to call the local authorized installer for a price on the installation. *One thing that I did not like...the only stock rim I can use is the 20" x 9". I do not like 20's at all. I prefer a 17" or a 18", but in this application, it will have to be an aftermarket rim. I do not know what the correct offset or backspacing is required. I don't like the look of "outriggers" on my truck. I wanted to run Michelin LTX MS2 295 x 70R x ? I don't know if Michelin makes a bigger LTX than that. Thanks again for the info. The BDS is quite a bit more expensive, but since this will be my last truck before retiring, I would like to do this truck "right" the first time.
if money is not a big concern I would look seriously into eliminating the torsion bars etc.
I hate 20s as well I bought some for my work truck but still driving around on the stock
steel wheels. but the trade off in ride I could learn to like the 20s. look to the bottom of
the page when you first open the forum and ask the guy his opinion.
http://www.gm-trucks.com/forums/topic/202235-bds-coil-over-2-3-kit-installed-on-2500hd/
Edited by miker2702
Miker: Thanx, I appreciate the info. Looks like all I have to do, is research an aftermarket 17" x 9" or 18" x 9" wheel. I've picked out an installer/vendor in Charlotte, and he recommended a website to visit. Again, I really appreciate the info, I'm not a young guy, and I want a nice smooth ride. I use my 1977 CJ7 for off road, but my truck must remain reliable, and not abused.
Talked to an authorized vendor/installer yesterday. He said to look at 17 x 9's or, 18 x 9"(8 x 180mm bolt pattern) with 5.5" backspacing. Just thought I'd share some helpful info, if you prefer something other than stock 20's. I prefer a larger tire profile, and they're a little cheaper on your wallet.
Glad it worked out for you.
I'm not a experts at all on these truck s. Went looking
For a.used 1/2 ton ended up
With a new 2016 2500 crew 4wd
For 29k.couldn't stand the severe rake they have.
Congrats on your new truck. I had a 2016 1/2 ton for about a month, and got rid of it. That cylinder de-activation, and clueless transmission shifting and vibrating turned me off. I could put 1500 lbs in the back and it was too much for the truck. I'm glad I went with the HD2500, it shifts flawlessly, and hauls the weight. It might be a bit thirsty, but I am more than willing to pay the price for a decent running truck. Plus, it's very comfortable.
Glad yours shifts flawlessly mine is often confused
  • 5 years later...
Maxx Cam 5 Level Kit is a great addition to any home studio or music room. This kit includes everything you need to record in a professional studio setting: two mics and two stands, a control room monitor stand, and a headphone amp. The Maxx Cam 5 Level Kit is the perfect choice for recording vocals, acoustic instruments, and electric bass. It provides an excellent audio experience with minimal noise. And best of all, this kit is affordable and easy to use. If you're looking for a budget-friendly solution for recording in your home studio, then Maxx Cam 5 Level Kit is the perfect choice for you.
heardle
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 938 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
