Strange Picture
02Blue
Scared the crap out of me after 30 seconds--that's what's wrong!!  You #$@%!@#.
Worth a "made you look", though--congrats, you got me.
And yes, I am a spaz--jumped 3 inches off my chair.
(Hope I'm not spoiling it for anyone.)
Brendan
My questions is how did that guy get a picture of my house??  That is the way it goes around here all the time, you never know when all #### is going to break loose.
Got me too........gave me that little scared adrenaline rush and tingly feeling.....wait a minute...sorry....spilled my coke on my lap..... :)
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
