I finally got a few hours to clean up my truck yesterday. Just posting because I love a clean truck as much as everyone else here.
  • 3 weeks later...
Nice job, I always like my white yukon totally cleaned we dont get the same reflection has darker colors but they do look sharp
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 298 Guests (See full list)
