Pinging sound at acceleration
As an aside from the E85 debate, which people will never agree on, I would think a dealer could reflash your ECM with a factory calibration using their diagnostic machine. I wouldn't think it would more than an hour of labor. If you want to run 87, get the proper tune in the ECM. Whatever tune you have, it has too much timing advance in it for 87.
Yes we got off topic but I think slimjim and i are probably closer to being on the same page at this point. Last i heard the dealer charges around 350 to reflash the truck back to stock, after all they are selling you a tune albeit factory. But you did say what i had meant to post also and that is, if the op is ok running 89 to stop the pinging then just keep rolling but if the op wants to be able to run 87 its going to have to be reflashed because as you said there is too much timing installed.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 668 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
