true story
96Z71asskicker
KILLER BISCUITS WANTED FOR ATTEMPTED MURDER (the actual headline)
> Lisa Burnett, 23, a resident of San Diego, was visiting her in-laws, and
> while there went to a nearby supermarket to pick up some groceries.
> Several people noticed her sitting in her car with the windows rolled up
> and with her eyes closed, with both hands behind the back of her head. One
> customer who had been at the store for a while became concerned and walked
> over to the car. He noticed that Lisa's eyes were now open, and she looked
> very strange. He asked her if she was okay and Lisa replied that she'd
> been shot in the back of the head, and had been holding her brains in for
> over an hour.
> The man called the paramedics, who broke into the car because the doors
> wer! e locked and Lisa refused to remove her hands from her head. When they
> finally got in, they found that Lisa had a wad of bread dough on the back
> of her head. A Pillsbury biscuit canister had exploded from the heat,
> making a loud noise that sounded like a gunshot, and the wad of dough hit
> her in the back of her head. When she reached back to find out what it
> was, she felt the dough and thought it was her brains. She initially
> passed out, but quickly recovered and tried to hold her brains in for over
> an hour until someone noticed and came to her aid.
> Lisa is blonde
Actually, there is/was a show on TLC or the Discovery channel that did a test of this story. An I think it could actually happen, but the biscuits would have to be in the car for like 3 hours in 100+ temps. So I guess it is POSSIBLE, but ver unlikely this is true. But funny, I'll give ya that!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
