So, how many get in the truck and begin a call or text message and the
....only to have the damn thing cancel out on you?
First world problems, I'm the first to admit. But crap. It happens to me over and over. Why does it do this?
Mine is not. I've taken full measure of the technology offered.
But I wish every one of my surrounding drivers were as diligent as you.
Meanwhile, why does the reverse process disrupt the origination of a communication opportunity? Camera?
Oh woe is me.
My truck is a call and text free zone.
If it's not an emergency (medical) it can wait IMO.
But the public can't resist the need to talk and text. A business owner I cut some slack. :happysad:
Guys - do you believe using the hands-free technology as designed is the problem?
I see the idiots that miss the signal, can't negotiate a turn, blindly enter the intersection, cross the center line, etc., all the time. It's really tempting to stereotype - mom or college kid - but the club is not exclusive.
I say well executed hands-free is generally fine. No different than having a conversation with someone in the front passenger seat. Just take some personal responsibility. If all you personally can handle is to ban the use 100%, then I am really glad you do.
But I'm hijacking my own topic. The question is (was), why does the technology cut out when you move into reverse. Typically from PARK I might add...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,122 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
