Part number question
deduncan
A friend of mine has a '98 Cadillac STS, and wants to buy a part for it. I remember dealing with a guy that I learned about on this board that sells Chevy and GMC parts pretty close to wholesale. I forgot his name/website/phone number, and am trying to find the best price for my friend. I'm not sure if he does Cadillac as well, but thought I'd give it a shot.
Friend of mine was quoted $140 at the local dealership here for the Homelink Transmitter Module (PN#12496720). If anyone has any info as to where I might be able to go to help him out, I'd appreciate it!!!
Is this who you are talking about. http://www.jpcustoms.com/Productpages/HomelinkGM.html
Here is the part price from http://www.partszoneonline.com/index.php
Description for Part Number: 12496720
TRANSMITT
Your Price: $106.74 Core Charge: $0.00 List Price: $155.01
Total Price: $106.74
And here is fromwww.gmpartsdirect.com
GM PART # 12496720
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $132.60
OUR PRICE: $92.82
Thanks a ton, I just caught the links on the left.
I do remember; however, a guy that worked at a dealership (I believe he was in the mid-west) that was referred to by a bunch of people on this board. He had pretty good prices on stuff.
I'm not sure if he could beat the $92 price, as that's the lowest I've found anywhere.
