Hobbies???
MarkD
What are your other hobbies
37 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I do alot of those things. I guess the number one would be computers followed closely by cars. Finally Audio-Video.
B.J.
I'm a huge hockey fan, then computers (can't really call it a hobby, it's how I make money), then salt water fishing when ever I can. Does drinking count as a hobby???
I fish...bass fishing. I spend most of my time from April to Sept fishing tournaments or trying out new lakes. The winter months are spent replenishing my tackle stock for the next season :)
I like doing all kinds of stuff. I starting hunting about 5 years ago, and would say hunting/fishing takes up most of my off work time. I do truck stuff to be able to do my hunting :)
"OTHER" :)
I play music, ALOT.
After that, listening to music, trying new microbrewed/homebrewed and imported beer, watching football and NASCAR.
Yeah...I like it.
Then there is this hobby....Not mine (I can't afford it), but I do spend a LOT of time spinning wrenches on it. It's a kick to drive though.
It's my next door neighbors drag boat.
Didn't forget boating, just knew I couldn't include everything.
Most of these things are hobbies of mine (yeah, I knowjack of all trades, master of none)
I didn't include a couple of other hobbies...
Skeet/Sporting Clays shooting
Woodwork
Way cool boat by the way. :)
