WATER SPOTS!!!!
JonesNTN
My truck is starting to show what appears to be water spots in the paint. Washing helps for a while, but it comes back after a few days without even getting wet. I've washed with different types of things, dried it after washing and waxed it several times. Nothing seems to make these things go away.
Can you help a brother out?! :)
My Tahoe is showing the same type of water spots. I have Zaino but haven't applied it yet. I guess I have the same question...what needs done to remove them? Will the Zaino claybar do the trick or is there something else that needs to be done before Zaino?
B.J.
While waiting for a response I found a site that recommends using white vineagar and the re-waxing since the vineagar takes off the wax. I may try it on my glass and hood.
This crap pisses me off to no end.
I use Z18 claybar, Z7 carwash, Z5 & Z2 polish, and Z6 gloss enhancer. Using an electric leaf blower to dry the vehicle helps, but I found that I needed a few coats of Z5 / Z2 to make it work really well. Using Z6 between coats of polish and when done finally eliminated the waterspots for me on my black vette.
White vinegar? Hmm...I may have to try that. I had a '97 silverado that had waterspots pretty badly and nothing would remove them. The only thing that came close was clear coat polishing compound but that was a big pain in the arm!
Anyway, let me know if the vinegar works.
B.J.
Vinegar helped some, but I think I need drastic help. I am going to take it to a detailer to be buffed here in a couple of weeks. Hopefully that will help the paint, I may even have him buff the glass.
Here is the info I found on vinegar from Advance's web site.
By: Leonard Emanuelson/autoMedia.com
Water should be a fairly harmless liquid. After all, we drink it, we bath in it and we even use water to wash our vehicles, so how bad could it be? The answer to that question depends on where you live and the minerals that are present in the local water supply. For example, the water in the Southwestern portion of the U.S. is full of hard mineral deposits that will literally etch themselves into paint and window glass if they are left on your vehicle for an extended period of time. Lawn sprinklers are the worst. Leave your vehicle where it gets water-spotted by the sprinklers, then baked by the sun, and the spots are not only difficult to remove, but they may do irreparable damage as well.
Offense, Defense
Like most problems, the best defense is a good offense. In this case, keeping a good coat of wax on your paint and window glass (that's right, use a glass wax) is the first line of defense against acid rain or water-spot etching. The second line of defense is to act fast to remove any water spots that may get on your vehicle. Time is relative. If you have a dark-colored vehicle and it stays out in the bright sun, you have less time to deal with the problem than a white vehicle in overcast conditions. It all has to do with surface temperature—the hotter it is, the tougher the water spots are to remove.
Removing water spots is fairly easy if you catch them soon enough. Re-washing your vehicle won't do a thing. Instead, mix up a solution of 1/2 distilled water and 1/2 distilled white vinegar in a spray bottle and carry it in your vehicle along with a soft, clean cloth. When you notice water spots, move the vehicle into the shade, let the surface cool down, spray the paint with this water/vinegar solution and wipe it off with the soft, clean cloth. The spots should come right off. Your waxed surface may be dulled by this solution, so apply a coat of wax when you get the chance
If you don't like the smell of vinegar and don't mind spending more money, commercial water-spot removers are available at most boat shops. They work the same way: Just spray the surface down and wipe off with a clean cloth. (I've found the white vinegar just as effective and a lot less expensive.) What if the water spots have gone too far and actually etched the clear coat of your paint or the window glass? More drastic measures are called for. For window glass, try a good dry scrubbing with 000-grade steel wool to remove the spots without damaging the glass. If that doesn't do the job, then the windows will have to be polished with a commercially available glass polish and a power buffer.
Because today's water-based paints are very delicate (especially the clearcoat), you'll want to experiment with the least-aggressive polish available. Try hand-polishing with a cleaner-type liquid wax. If the spots persist, then have a professional buff the surface with a fine polishing compound and machine buffer. Follow with a good hand waxing. Today's clearcoats are very soft and thin, so make sure that everyone who attacks water spots with a power buffer knows what they're doing. Ideally, you'll keep the water/vinegar "first aid kit" handy so that the water damage will never get to this point.
New vehicles and new paint jobs are expensive. Keeping your vehicle looking new will add miles of driving pleasure and protect your investment.
Thanks for posting your results. I washed my tahoe this weekend and there are definately water spots that won't come off. They aren't as bad as they were on my '97 truck so maybe I can get them off with the vinegar treatment. I'm going to try it here in the next couple of weeks and then put a couple coats of Zaino on it and hopefully it won't happen again. They seem to only be on the hood so if I have to use the clear coat polishing compound again as a last resort at least I won't have to do the whole vehicle.
Thanks again.
B.J.
  • 4 weeks later...
Well dropped my truck off for the detailers to work on. He says he will essentially have to go through a 6 -step process and follow up with mequiars no26. Cost $130. I'll let you know how it works out. He said he doubts he can get it completely out of the windows though.
My truck is Onyx Black with a bad case of the pox. I've tried the vinegar with a lot of work and small results. A cleaner wax was a last resort but it still left traces of the spots. The glass is a lost cause for some reason. I've tried Bon Ami and RainX glass cleaner (very abrasive) with limited results. Someone could make a fortune for a fix.
He also asked me about my Truck washing habits. He said never wash it in the sunlight or even while it is hot. He aslo said that I need to be drying the paint instead of letting it dry or just driving it off.
I have the same problem on my Z71. The water spots are on my hood only. They are definitely etched into the clear coat because I used meguiars medallion paint cleaner 3 times on the whole hood and the spots are still there. I also followed the cleaner up with meguiars #7 pure polish, then #26 high tech yellow wax. It helped, but I can still see the spots. This is what I get for letting my truck air dry everytime I wash it. The only way to get these spots out is to have them removed by a detailer. (use a rotary buffer) As a result, I will never let my vehicles air dry. Oh, my truck is black which doesn't help the situation. You can see everything with black!
1998 Z71 ext cab
5.7L
BTW - did you happen to find out what they used on the windows to get the spots off?
Real fine grade steel wool and Clearcoat compound.
Thanks! :thumbs:
My father has an 85 Vette and the spots on the side windows are really bad. We'll have to give this a shot and see how it turns out! :chevy:
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
