Foreplay
MarkD
Two women were playing golf. One teed off and
watched in horror as her ball headed directly toward
a foursome of men playing the next hole. The ball
hit one of the men, and he immediately clasped his
hands together at his groin, fell to the ground and
proceeded to roll around in agony.
The woman rushed down to the man and immediately
began to apologize."Please allow me to help. I'm a
physical therapist and I know I could relieve your pain
if you'd allow me."
"Oh, no, I'll be all right. I'll be fine in a few minutes,"
the man replied, still in pain, in the fetal position, still
clasping his hands together in his groin.
But she persisted, and he finally allowed her to help.
She gently took his hands away and laid them to his
sides, loosened his pants, and put her
hands inside. She began to massage him.
"How does that feel?"
"It feels great, but my thumb still hurts like hell."
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
