Carfax
MCourson
Would you check mine I'm pretty sure it's been wrecked as the taligate does not line up completely.
Thanks,
the vin is 2GTEK19R8W1522766
Clean. But it was first listed as a commercial vehicle, then as a manufacturer vehicle, and then as a dealer vehicle.
