Water pump replacement
Fixin to approach 330,000 miles on original pump, question is what else would y'all recommend doing while I'm down there
Check all idler pulley bearings. Probably a few of them are making a little noise. You can just usually replace just the bearing. Also, new fan belt if the old one is getting dry and cracked.
Thermostat; while you're working on the pump it's cheap and easy to get to. Coolant reservoir pressure cap. Again, cheap insurance.
