Scraping noise in driver's window?
After I installed my weathertech deflectors on my windows, I'm getting a scraping noise on the driver's window, although it doesn't happen towards the top of it's travel like you would expect. It happens when the window is almost all the way down when the deflectors aren't even close to the window.
Anyone ever experienced this? Perhaps it knocked something out of alignment on the window track when I installed?
Is it relatively simple to get to the window hardware? It's a 2000 Silverado LT Z-71, by the way.
mine does that and it doesnt have anything to do with the visors. My pass side did it a yr ago and they changed 2 things under warranty
