I remember when my truck was untouched and new my steering wheel controls would light up but then I put an aftermarket stereo now my controls don’t light up anymore is there a fuse that I could replace for the back light to work ? 2014 Silverado crewcab
My 14 did the same thing. I don’t think it’s as easy as a fuse. I remember that the instructions that came with both of the SWC adaptors it tried specifically mentioning that the back lighting would not longer work.
Until I got my 17, I honestly forgot that they used to light up and I had no issues just doing it by feel.
Yea that’s probably what mine said as well thanks for the reply
That's interesting to note.  The only time I have seen mine not "light up," was about a year into ownership, and then I cleaned my steering wheel, removing dead skin cells and wife's makeup residue.
Recently, I was looking at replacing my stereo with one that has NAV and a 6-disc (MP3 compatible) changer in it, like my '10 Ridgeline did.  But now, maybe, I'll put that one on the back burner, until I find one that I know for sure will work with everything else in my truck.
  • 5 years later...
I changed the stereo and the steering wheel control switches about the same time, so I wasn't sure why the new ones didn't illuminate. Now I know!
  • 5 months later...
i swapped harnesses and I am not using the Maistro and the controls are illuminated.
  • 6 months later...
how did you get them to illuminate?
  • 7 months later...
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,138 Guests (See full list)
