Gulf Stream Motor home
HLBetke
I have a 2002 Gulf Stream Motor home it has a workhorse chassis with an 8.1 V-8mfi engine I understand it has a road-speed limiter the problem is it will top out at 72mph when it is suppose to max out at 80mph ! how can I solve this problem ?HELP no one seems to know how to fix this problem ! I cannot believe that I am the only one that has run into this !
If you are not drag limited, then the limiter is likely controlled via the onboard computer, you'd need some sort of tune tool to connect to your OBD-II port to lift the limiter.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
