Courtesy car
my dealer offers one if i need, where i used to work we always gave upgraded loaners to increase sales.  But i do hate going from a truck to a micro car!
On 11/1/2017 at 5:23 PM, Redoo2000 said:
I was told by Smithtown chevy that they won’t give a courtesy car until they have it for a day and figure out the problem. How does that make sense. I’ve dealt with Nissan and Acura in the past and always received a loaner on the first day. They told me it’s GM policy. Anybody have this problem??
Well your problem is right there.  Smithtown Chevrolet is the biggest bunch of crooks on the island.  They are an absolute joke.  Go somewhere else.  112 or Atlantic.  Im in Port Jeff and I bought my truck and service it at Atlantic, well worth the drive.
When i was buying it, Smithtown wanted 3k more out of pocket and 150 more a month, and that was the lowest they got.  Also told the salesman to run numbers on a 6.2 and he told me "they don't put a 6.2 in the 1500s, you need a 2500 for that".  I called him a moron and left, didn't even give him a chance to correct his mistake.  My father had a similar experience when he bought his suburban, salesmen didn't know what options were available and what weren't.  Held his trade hostage while giving out horrendous pricing.
All dealerships are crooks
I got a good deal on my truck
I just never heard of such a policy
hope you did, because they weren't even in the ballpark that 112 and Atlantic were.
Does atlantic have same policy with courtesy car??
    Greg3160
    Greg3160
  • Who's Online   0 Members, 0 Anonymous, 446 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
