2016 Silverado 1500 knock
Dantree1234
Just bought 2016 Silverado 1500, has a weird knock coming from underneath the truck, I’ll be driving along and then give the truck gas and then as the RPMS drop a weird knock happens, it does it every time I do it, I’ll be driving 30mph get into the gas a little bit completely let off the gas and as the RPMS fall a knock happens out of no where, anyone have this problem?????
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
