Lost all Electrical Power -00 Bravada
My parents recently purchased a 2000 Olds Bravada and about 2-3 weeks ago they went to start it and it lost all power. Figuring the battery had went dead it was replaced with a new battery and it also received a new positive battery lead since it was corroded. After replacing those pieces it started right up and seemed fine. Just a couple days later it did the exact same thing. No electrical power at all. A GM tech looked at it and said that it was most likely a bad alternator. So it got replaced as well. Started right up and seemed fine. Tonight I get a call and it has happened yet again. Since they were in a restaurant parking lot I drove over to see if I could get it started so it could be drove home. When I arrived I went to make sure the positive battery cable was tight and when I put the wrench on it the under-hood light came on. After fiddling with it, the truck finally started. The connector was tight on both positive and negative terminals. When it loses power when you try to start it, the truck will lock the key into the ignition and it can't be removed. :cheers: Thoughts?
Thanks!
I would make sure the new positve lead was good as well as the negative. Also check the ground wires and the cable to the starter.
I assume that the belt tensioner and fan belt are also in good condition, as they should have been notcied when replacing the alternator.
Beyond that, My dad had a similar problem on a 93 blazer theat ended up being a relay on the firewall. It was intermittent like that, but I don't think it caused a loss of 12 volts to the system.
You could also have some other type of short in the system. Perhaps it will need diagnosed by computer.
Since they recently purchased it, I am hoping the dealer is standing behind it!
Good luck...
Thanks for the reply.
Positive and negative leads are good.
Belt tensioner and belt seem fine as well.
The truck hasn't been purchased "that" recently, first of april, so no warranty. They purchased a warranty from Warranty Gold, but Warranty Gold is trying to go out of business therefor they aren't paying claims! Ughh! I purchased a Yukon three days earlier than them and my warranty is also in the can.
I had a similair issue with my 97' blazer. It would intermittently cut out while running. Shut off, stop dead. Then it would not want to start, I had 12 volts to the starter, but it wouldn't pop. This would occur intermittently and my shop had trouble finding the problem.
Ended up being my ignition switch. There is several wires going to a harness that support that. When it went out I couldn't even shift it out of park. Something to check out.
bowtie_pasta,
The "won't shift out of park" is very familar. Once it happens it locks the key and you can't shift out of park. Hmmm, might have to look into the ignition switch. Anyone have an idea of cost to replace the ignition switch? :rolleyes:
Thanks again! :cheers:
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
