FS: Jet Chi
Jet Chip
Not sure if it will work on other engines but it works on my '02 5.3. Doesn't have any instructions but I can tell you how to install it. It's simple!
Will sell for $100 plus shipping. Post zip code if you want a shipping estimate.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
