Need some GMT800 Gear Swap Advice
I have an '07 Silverado Classic, 76k miles.  2WD, 5.3 engine.  Unfortunately I have the 3.23 gears and it's pretty sluggish getting going.  I planning a gear swap and can't decide on which size to go with.  I have 265/70/17 wheels. Don't do a whole lot of towing, but occasionally haul building tools and lumber around.  Mostly short drives back and forth to work, in TN hills.
I had thought of going to 4.10 and getting bigger tires later on (and a higher lift).  I think I'm going to pass on that though, no lift, sticking with the 265s.  So now maybe 3.73 would be better, or 3.90?
unfortunately you have 3.23? haha ive got the 3.08s. I have been contemplating the same thing. If you stick with your tire size, 3.73 has always been the best all around gearing for mpg and towing/hauling etc. The 3.42 I think is a good option as well, youll get some acceleration/torque back and still keep a little more mpg than the 3.73. I'm stuck between 3.42, 3.73 and 4.10 and I'm only going to do it once so I haven't pulled the trigger yet. My truck is a Z60 (handling package) so I think it would be a blast to have the 4.10 but don't want to lose more mpg than what I already am having the 3.08 and lugging the engine. mine is a 6 speed so at 90 its turning like 1800 rpm. Also, there are plenty of gear calculators out there online so find one that lets you input your transmission top gear ratio, mph and tire size and it will let you input gear ratios and tell you the rpm at whatever mph you input
3.08 would bog me down sooo bad. This is my first truck, just got it late last year, so I didn’t know to check gearing. I got a pretty good deal on it, so I don’t mind putting some work into it.
Ordered the 3.73 gears :)
I never would have thought a truck would have 3.08s so it never occurred to me look. my lifted truck with 35s and the 4.8 and 3.42 was less of a dog than this one is. hope you looked into install prices unless youre going to do it yourself. shops charge a ton
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
