BCM without ECM
So i am wanting to do an engine an engine swap on my 04 chevy 2500HD 6.0 . Now my question is this, the engine/trans I am going to be swapping in does not require a computer to run.  I am wanting  to remove the ECM but i do not know if the BCM will still function without the ECM. so that IS my question. Can I rempve the ECM and still have my electric windows, HVAC(digital), turn signals, lights and all still work or will i have to keep the ECM in for it all to work?
thank you in advance.
Mike Clark
Nope. You can keep the BCM and everything in the vehicle will work. Kinda like when the ECM goes bad on the vehicle and doesn't communicate... BCM will still do everything. Most of you BCM is on Low speed data. Only the security part is high speed data.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
