I have a 2018 3500hd w/t. It has the bigger screen for radio and backup camera. I have chevy my link. It has 5,000 miles on it. About 2 weeks ago the radio doesn't get any louder after the 40 on the volume adjustment. It had a very loud radio before this, but now it continually gets louder until 40 and then stays the same volume the rest of the way to 63 and even seems to get quieter when cut all the way up. I have checked teen driver mode and it is turned off. I have also turned off auto-volume. Any help is appreciated, I can barely hear anything via bluetooth or usb and is lower than I would like on radio settings. I have searched and searched the internet and this must not be a problem for many.
Reed, if you’re like me - just past middle age, married - the old “I can’t hear squat” is just a unfortunate truth when listening to music.   Conversely can be a blessing in other ways....
That wasnt really helpful, I know.  Sorry.
  • 3 months later...
My 2018 Silverado doing the exact same thing my buddy at dealerships said the radio needs to be flashed or reprogrammed that should be first step then go from there
New here but ran across this thread while trying to figure out the problem on my 2018 2500HD. I had  the exact same issues. Stopped to fuel up and noticed the volume wouldn’t increase and actually got quite past 40.
Racked my brain and realized the volume controls while using Apple car play and navigation via iPhone were independent of the radio volume, meaning when the navigation voice is playing the volume knob will adjust independent of the radio.
So so I plugged my phone back in hit a destination waited on the voice to come up and adjusted the volume and voila! Radio is functioning as should. I think this is probably a software issue, resetting the radio didn’t help nor did disconnecting the battery. Hopefully this helps the next person having the issue.
Keep in mind the turn by turn voice had to be talking in order to adjust the volume, so it’s a little tricky but it definitely fixed the issue. Maybe someone from GM can chime in and explain why
  • 11 months later...
2016 gmc 3500 HD This worked for me as well thanks
Edited by Russelyle692
This worked for me as well. Thank you Rush2252. I was using Waze with Apple Car Play in a 2018 Camaro
I have a 2017 Chevrolet Camaro. Out of the blue, my volume level won’t go past 40. I’ve tried EVERYTHING to get it to work. Unplugging paired devices, removing paired devices, disabling  teen driver mode, calling Chevy Customer Service, calling onstar, software updates, restore system settings, etc etc. I’m just past the 36000 bumper to bumper warranty so they want to charge me over $100 at the dealership to fix it and I don’t want to pay that. PLEASS HELP! This has been going on for over 2 weeks now... no resolution. Thank you so much ☺️
  • 5 weeks later...
  • 5 weeks later...
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
