Harness for truck to rear trailer plug
My truck is 2002 GMC Sierra 2500HD. It has UY7 RPO code. It has a harness, but some wiring genius screwed it up, long story short. I want to start fresh, and just replace the whole darn thing from truck to plug.
I have found harnesses for UY2 RPO code, but not sure if they are the same. Some of the reviews say it was "the wrong one", but don't mention why.
Can anyone direct me to the correct part number?
Larry
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
