Torsion bar to LCA fit
I've been trying to track down a clunk for a while now on my 2005 ECSB Sierra 1500 with 181k miles.  Ball joints seem ok, just about everything steering related has been replaced (including pitman and idler arm, upper intermediate shaft and shaft bearing).  So I was under the truck looking at control arm bushings, and noticed the fitment of the torsion bars to the lower control arms looks non-precise, so to speak:
Does that seem like a normal fit?  The blurry pictures are there to show light coming through.  If it's supposed to be a tight fit, I'm wondering if as the suspension cycles, the torsion bar can rotate a bit and cause the clunk I'm hearing.
That's normal fit. Now. Goto the very back of the torsion bar and push it up and down. See if there is any play there. A lot of time you have problems with the torsion bar link bushings. That's where a lot of noise comes from when they are shot.
Goto where you see these mounts and lift and pull down on them If there is play replace them. They have knock out pins so you will need to buy nuts and bolts too.
https://amzn.to/2H8Qb10
Thanks for the info!  That's one more thing to rule out at least.  I'll check out the torsion bar bushings to see if they're causing the clunk.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 363 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
