Classic Oil pressure problem (Where should I start for my case)
Hey, I have a 2009 GMC sierra 5.3 L V-8. About two months ago when I was on the highway I looked down and noticed my engine light was on and my oil pressure was around 15 PSI. I turned my tuner on and saw that the engine Was saying low oil pressure so I pulled over. I checked the oil and it seemed fine so I continued on. For the last two months when I started it is at a perfect 40 psi and as I keep driving it, it keeps getting worse and worse. After about 10 minutes it is down around 30 psi but when I shut the truck off and let it sit for a while it goes back to 40 next time I start it. When I’m on the highway at 2000 RPMs it is around 23 psi and 4000 it gets up to around 34 psi. I drove it about 100 miles yesterday and it got so low the oil light came on and started beeping at me. I pulled over and let it sit for awhile and I put some oil treatment in. I drove it another 150 miles and it stayed around 20-25 PSI the whole time and the light did not come back on. I took it to a dealership and they told me I need a new oil pump, I was going to take their word for it but I started researching it and saw all this stuff with the oil screen and oil sensor being clogged. In my case what do you guys think I should start with? The truck on it has 80,000 miles on it and I have change the oil every 3 to 4000 miles. It seems to drive fine and I noticed no difference in the performance. I was thinking of replacing the screen and oil sensor first then going from there if that doesn't fix it? Thanks
If it was me, I think I would try the oil screen and sensor route first.
Sensor, screen and an oil change.  Grab an AC Delco filter, either a PF-48E or UPF-48R.  Worst case, its a pump or pickup tube o-ring issue.
Alright thanks guys. I think im going to put in a new screen/sensor and change the oil and filter and hopefully, it works. If not then ill move on to the more expensive options.
  • 3 months later...
I assume your talking about the screen/filter under the sending unit, not on the pump pickup.
I guess if it were me, unless it was making noise, I would install an actual oil pressure guage (for testing) and monitor it and see if it corresponds to your symptoms. If it doesn't, then it's that sending unit
