Bed lights
Came across Lux lighting and seems like a neat and simple kit, very small with strong magnets. Has anybody added led light to existing bed lights or under the bumper for back up lights? Really looking to see how some did the bed lights, also is there a way to override the switch so the cargo/bed lights could come on while going down the road?
I have few water proof LED light strips i plan on putting in the bed, just piggy back on the current wires and it should all work fine.
I havent seen anything about the cargo lights but you may need to put a relay and a switch to power source and basically go independent of the current system.
my bed light kit came today.  As soon as i find the plug in the back of the truck for the factory lights ill post how i did it.
