Hyper tech tuner
Just wondering if anyone did the tune on a 2018 Silverado with the 5.3 8 speed.
I turned the V4 off regular fuel and throttle response is on street. There is no update yet for the 8 speed trans. My question is the shifting seems funny then before I did the tune. It seems to be holding a gear when letting off the trotted certain times and you can feel it coming down on the gears. I know these trans are not the best as far as shifting wise. Just wondering if tuning makes it so it has to relearn your driving or could it be the tune.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
