Scaled the new rig
Had to drop trailer off at rv dealer for mvi, figured I'd get it on the scale. Hitched up, pretty close to my old Silverado. Tows beautifully compared to my old 09 Silverado though.
I figured I'd have to adjust the hitch some, but it tows so nice, not sure I should mess with it?
In order to know the tongue weight and the exact percentage you restored to the front you also need to weigh the truck with the trailer hooked up but the WD bars disengaged.  But any numbers help, and from the numbers you do have, it does look like you're probably pretty close to the 50% level GM recommends, and under all your maximums.  So if it tows really well you can probably just be happy and go with it.  If you're a bit OCD or just curious, it wouldn't be a bad idea to take the third measurement but nothing is way off so you'd only be looking at minor adjustments anyway.
Good to know. I'll see if I can't run it by the scale again. Thanks!
15 hours ago, Roscopcoletrain said:
Tows beautifully compared to the Silverado though.
what year was your silverado?  are you comparing the same year or previous model?
it was my 09 I traded in for the 15 Sierra
yep...my 2016 silverado pulls way better than my 08 Silverado also...your post made it sound like the Sierra is way better than the Silverado...I probably just read it wrong on a Monday morning...but yes, I agree the new models are definitely an improvement over the previous...
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 698 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
