4 wheel drive disengages
troostbob
I have a 2014 Silverado 1500 that when I'm driving through any type of slippery terrain, the 4 wheel drive stops working. I'll get a message that says 4 wheel drive off. After shutting the truck off and re starting, it will re engage than almost immediately disengage again. Any thoughts??
Sent from my XT1585 using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 674 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
