K2XX Bug Deflector
Howdy GMT,
I was given this free bug guard from my moms coworker off his 2016(?) Silverado. It looks like it fits my 2018, but it’s also got some nasty sharp clips to hook it on. I’m going to try and sandwich a rubber washer between the clip and hood. Any other suggestions? I don’t want to mar the hood and would definitely add some mounting tape if it helped. Thanks in advance!7b26c87499cd53df2ab43c3a73e98d12.jpg43076bdc9ab13fa047bb4745c890ffb6.jpg
Howdy GMT,
Are there holes in the bottom of the hood for those to go into never seen those before I bought an areo skin for my 2014 it turned out pretty good I think ea2f08d7d675b1a47289a749fc45df50.jpga11705ee20e2c212e7503054ddf80337.jpgee75145aadbdb5d4e5b4e0e3c0134f78.jpg
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 193 Guests (See full list)
