Looking to add a sub to my '15
I have a sub and amp that i want to put in my '15 double cab. Building a box, wiring, etc isn't an issue. However, in all my previous trucks I've replaced the HU when doing my install. This time around i want to keep my factory in-dash/nav setup.
I know i can use an LOC and tap into signal that way but it's not my favorite option.
I know I can use a signal processor and tap into all the speakers and get signal but I would also have to amp my other speakers. (this is the long term goal).
What can i do in the mean time? I've heard PAC-Audio makes a device that hooks into the radio brain and gives signal outputs but I can't find anything.
Thanks for any help you guys have.
Audiocontrol Lc7i.
That’ll give you a good alternative to an aftermarket Hu. I had one in mine until I got the alpine restyle.
My long term goal is an LCQ-1 and amp all my speakers. But right now i just want to add the sub.
Looks to be like the Lc7i is like the LCQ-1 and i would have to transition my fronts to an amp sooner than later. Is this true?
The lcq1 is the upgrade from the lc7i. I didn’t have to upgrade my speakers. I had originally wanted to keep the factory HU until the alpine came out and had planned to upgrade all my speakers with it so I went ahead and got the lc7i. Do note I had the Bose audio so the sub wiring was already there to take the signal from.
I think after more review the Lc7i is a cheaper and just as good option for me. I don't have the bose option so that's probably where my issues comes in with having to do all or nothing.
I guess i'll grab one and not install anything until i have my 4 channel amp/speakers in-house.
Your help/input is greatly appreciated.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
