Intermittent hydroboost issue
Hi all, I Hydroboost swapped my 02 suburban about 4 months ago with all new ac delco OEM PS pump with the 1 ton pump and deleted the EVO, 1 ton cooler, 2011 duramax hydrobooster, brake pedal, hoses/lines, pulley, master cylinder, booster gasket and new 2013 tahoe PPV front calipers, also replaced the rear brake line. The entire system was bled properly and firm and would lock all the tires up. Now after a hard brake a few days ago the pedal is as soft as a vacuum pump and takes almost all the pedal to slow it down. Not close to how it was. The fluid is amsoil fully synthetic PS fluid and the ps/hydro was bled as well, there appears to be no issues. However, I recently noticed an air noise behind the steering wheel at idle and am wondering if the hydrobooster might be bad. Does anyone have experience with this?
