heater controls
:cool: Have a 01 gmc serria that i need to add heated mirrors.Am needing to replace my heater a/c control with one that has the defrost switch .Anyone done this and were did you buy the control unit .Could really use help on this one getting cold up here,thanks
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
