Need 4WD help
I have a 1996 Tahoe and the 4WD isn't working. I figure its a bad actuator, but I was diagnosing it and only have 12 volts to the actuator when the shifter is in 4 LOW and not 4 HIGH. Does anyone have any clue why this would happen? I think I have a bad actuator and no voltage....
Any help would be great.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
