2011 Silverado 1500 5.3l rough start
My 2011 5.3l Silverado with 58000 mi. has codes po172 and po175. It runs rough on cold starts and sometimes feels like a miss waiting at stoplights. I have tried cleaning mass airflow sensor. Today I changed spark plugs and have ordered new mass airflow sensor. Still runs rough. Any ideas? Thanks
Mass Airflow Sensor (MAF)
Defective Manifold Absolute Pressure Sensor (MAP)
Engine mechanical problems
Defective Oxygen Sensor
Defective Fuel Pressure Regulator
Defective Coolant and/or Air Temperature Sensor
Thermostat is stuck open
Ignition Misfires
Defective Throttle Position Sensor
Defective or restricted fuel return line
Defective Fuel Injectors
Sefiroxx. How do I narrow it down from all these possible issues?  I got the new mass airflow sensor today and will install tonight.
You'll need a one scanner with an ability to read data streams as well as other tools: some failed/failing items will throw a code, others will just provide bad data.
- scanner to confirm amount of flow
- scanner to confirm proper atmospheric pressure
- tool to check compression
- scanner to confirm voltage signal and STFT
- fuel pressure test guage
- scanner
- engines does not get warm enough
Ignition Misfires
- code set
- scanner to show tps angle and that it moves smoothly
- usually misfire code or excessive LTFT numbers
Thanks for all the broad ideas. I searched a little further and found a video
about these flex fuel motors resetting with wrong alcohol content settings. I brought it to my mechanic he said it was running as if there was 58% ethanol in my fuel. I don’t know where you gas up but my 87 contains no more than 10% ethanol. It was literally a 2 minute fix. Wasted my money changing the mass airflow, the spark plugs I’ll chalk up to preventative maintenance. I hope this helps someone searching with the same issues.  After resetting my truck runs and starts like it always has.
