AM/FM Antenna Cable Install
nateb21
I started having issues getting AM/FM reception, started digging and found that it wasn't securely in the antenna base. How does this need to be installed in to the antenna base? Shoving it back in to it doesn't seem to work, anyone have any good suggestions so I can get some reception back? Truck is a 2014 Silverado
If I remember right, the cable is permanently attached at the antenna side.  It's  pita to get to all the little clips too.
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 851 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
