Has anyone had the lighting level of the Infotainment screen occasionally not brighten in the daylight or not dim in the evening? Seems only to happen at the first "changover" after first started. After that first cycle/start it works automaticly as it should. When it doesn't brighten or darken as required, I manually cycle the dash brightness toggle till it is visible in the daylight or not blinding at night. Most times it works correctly.
Sometimes it takes a few minutes for the ambient light detector in the top-middle of your dash to detect the light level at vehicle start-up. I use the remote start feature often and remove the sunshade I use in the front windshield after pressing the start button to run the vehicle. It always takes a few minutes for the instrument/ infotainment brightness to adjust to the ambient light. It’s an engineered delay to prevent excessive dimming cycles when passing under overpasses in daylight and under street lights at night.
We appreciate your honest feedback in regards to your infotainment screen brightness, Bob. To clarify, have you brought this to the attention of your servicing dealership? We hope to hear back from you soon with an update.
Anthony J.
  • Confused 1
Anthony, thanks for your interest but during the present holiday season, the Infotainment screen will have to wait till the new year. It did happen again this AM, the next time it comes up I'm going to let it try to correct itself and see how long that takes.
Appreciate your help.
  • 10 months later...
This same thing happens to my 19 Z71 almost every day. It’s quite frustrating. Dealer has never heard of it happening. I haven’t scheduled an appointment yet for them to troubleshoot.
When changing from day to night - I can just tap the +\- button down once, and the dash and infotainment go to the appropriate ‘night’ setting. Doesn’t work the other way around though. I drove for almost an hour and it didn’t change to day mode. Also interesting that it doesn’t happen when just going ‘dark’ for a short time like a tunnel or garage. Mine also seems to only do it when starting the truck.   Like if starting it up in the morning after parking it in the dark. If I’m actively driving when the sun goes down, it usually changes over fine.
Z71NY nailed it. That is exactly what mine does. You can get the darn thing to "wake up" in the morning by turning the light knob to off then back to automatic.
The dealer didn't have a clue when I mentioned this to them 6 months ago, but they did suggest I purchase some mudflaps and clearcoat protectant!
Did the dealership fix this issue after almost a year?
the screen is washed out when I  back up and I can"t find out how to get some contrast so I can see items better.  No one knows how to adjust the contrast of the image .
  • 3 months later...
It’s a common issue. I had it on my 2019 but it appears to be fixed on my 2020. My Dealer never was able to fix it.
Great......
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
