On 12/29/2018 at 7:16 PM, jjcamper said:
I'm having a problem with my 2016 Silverado 4x4 with a locking differential and 4.3 V6 engine. Not sure if it's the transmission or the locking differential but sometimes when I shift from park to drive or reverse to drive and start to take off the engine will rev like it's in neutral and then bang into gear. Has anyone had this problem or have an idea what's going on?
JJCamper, I don't have a 4x4 but I do have a Sierra v6 that had similar issue. See here what the dealer found after I was told previously that it was normal operation. I also noticed it was worse when the transmission got up to temp.
Oh, forgot to add hen shortly after the above work was done around 600 miles started doing the hard downshifts again and they found quote " Found several valves in the valve body scored due to metal in transmission at last repair of torque converter failure. This is causing valves to bind and stick intermittently when hot." They had to replace the upper and lower valve body assembly. You think they would have flushed the transmission after the first repair a few times.
Edited by Morenar
Added comments
I am hoping that mine is not that serious but they won't even acknowledge that there is a problem. My truck shifts ok it's just the problem on takeoff.
  • 10 months later...
On 12/29/2018 at 7:47 PM, SS502 said:
Lots of discussion, check out this thread:
I just posted a thread about this same issue but I don’t see where this link / video you said included a lot of discussion about it is relevant to the issue the OP stated,  which is identical to mine?  Do you have the correct link? Thanks
These gm 6-speeds eat torque converters and often ruin the transmission in the process. Our 2017 suburban with the 6 speed is having the same problem at only 93k miles! Our 2009 tahoe with the same transmission also had the same torque converter failure at 107k miles. Neither was used for any significant towing. GM really screwed the pooch with the tuning on these transmissions; they burn up the torque converters with the constant locking and unlocking of the clutch and partially engaging... and getting tons of wear in an attempt to get a slightly smoother shift and a tiny fraction of a mpg better. They have known a long time they have a problem with these torque converters getting burned up, but in 10 years they have only made the problem worse with more TCC cycling. The 2017 burban unlocks the torque converter every time the thing goes into V4 mode, so every little change in engine load on the highway like a small hill results in more torque converter cycling... Hate to say it but this is likely the last time I will purchase another GM truck/suv. Sick and tired of expensive, premature transmission failures. I work in an industry we all have full size trucks and we rack up miles quickly on the road. The Nissans, Fords, and Toyotas are all getting 250k+ miles without major work on their drive trains, but ALL of our Chevrolet and GMC guys are all having major transmission problems either from day 1 (8-speed) or the torque converter burning up and causing the rest of the transmission to be ruined in the process (6-speed). As a mechanical engineer myself, this is simply a disgrace of engineering and quality control, and makes our group of engineers still driving the GM branded trucks look, quite frankly, stupid. I thought (hoped) GM had grown out of their old ways... I'm not so sure anymore.
On 4/2/2021 at 9:19 AM, damcaat said:
Jjcamper, did you ever get a resolution to the harsh/delayed shift into drive?
I know this is old but having the same problem, did you get any info on this issue?
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,734 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
