Fuel Gauge Reading Empty No Start
Hello,
I'm new to the group and wanting to see if anyone has heard of my current ground problem I'm having on my 2001 tahoe 5.3.
Originally, tahoe began with no start then wiggled my neg side on battery post turn key off/on and would start. After couple of days doing this procedure, I tighten the batt neg side and tahoe drive fine for approx 3 days or so.
A normal early morning I turned key on and noticed my message blinking empty and fuel gauge reading empty, when previous night I pumped in 20.00 worth of fuel.
Check 1. Relay, the  ecm fuse 2, ECM fuse 1, rechecked neg, did a system reboot bat off 30 min fuse out and relay out, etc...no luck. I jump the prime with hot wire from bat and boom it worked. Drove for 1 day and problem came back.
I replaced fuel pump thinking sending unit out, problem continued. When it's not functioning, I'm not getting a continuous 5v to the level sensor, so replaced wiring harness at tank, no change. Hot wire prime again, no change, hot wire relay...pump engaged and fuel reading half and it started.
So now I'm thinking ground issues... I traced and cleaned the following:
Batt neg to front frame/driver block
Ground strap driver side to body
Ground under driver door
Ground strap fuel cap to rear frame.
It seems to start as of now, but not sure if problem will continue because at those ground contacts my fuel gauge wouldn't ever read empty when those were disconnected for cleaning.
I do not see a ground strap on passenger side behind motor, what am I missing? Pcm connection looks perfect with no corrosion on contacts. Any advice would be great. Sorry for the book...
You mentioned you jumped the hot wire and it worked,so power problem not ground,I would investigate feeds to relay center, sometimes you think you have good power,but under load is a good testing method,while cranking when problem appears, check voltage at fuses,or a wire wiggle test while it's good and try to make it misbehave
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
