Westin
I just fell into a pair of Westin bars off of a 88-98 body style ex-cab.
At first glance, they look like they might bolt up to my 02 with minimal modifications.
I'm not at home right now, so I can't give measurements, but did a quick measuring last night, and they appear to be of the correct length.
I'm also not sure I want them on there...I like banging my head when jumping in a little too fast...So if they will not go...I might be selling them soon.
Any help on this would be just grand.
Dese be da bars:
Thanks for the help.
Those look like they may be for an extended cab. Is that correct?
The mounting brackets look like they are just like mine on my new body style '99. Not sure if there is any differences betweent he new body '99's and the '02's though. You probably already know that the brackets have slotted holes so some adjustments can be made, but on mine, as the sit on the truck right now, they measure 77 1/2 inches from the front edge of the front bracket to the rear edge of the rear bracket.
Here's some pics for you to compare.
http://tommy3z71.homestead.com/cps_steps.html
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
