Backup lights
Does anyone have aftermarket backup lights installed on there hitch? Kinda like the fog lamps you would put on a grille guard or something, but attached underneath in the back, with the auxilary lamp switch in the cab. Ideal for backing up to a trailer at night or whatever.
If so, do you have any pics, and where did you get the lights from?
Thanks :chevy:
Found these at stylinconcepts.com:
Back up lights
I got the white night setup, finally got it hooked up a while back, really bright and looks factory, or at least somewhat factory. I got the fixed mount model and had to do some modifying to get it to fit right. I just went on a 1500 mile trip pulling a 1000lb trailer, half the time unloaded, now the lights dont work anymore, maybe the bulbs got a lot of vibration or the relay went, gotta check it out and then maybe i can post a pic. Any ideas?
Thanks for the replies guys. I like that White Nite setup. I was thinking of doing what MCourson did and mounting 2 lights directly to the hitch and wiring it all up myself. :D
Lots to think about. :crazy:
03Bluerado, regarding the lite's being out now, maybe the wiring connection is bad, or the relay went like you said. Could be a couple of things. I am not too good with that stuff though.
:rolleyes:
I've got a set of KC backups that a shop nearby put on. They are mounted using brackets which are held on by the bumper bolts I believe. They're spaced a bit wider than MCourson's. They do a great job when you're backing at night. I actually got the 4 pod housing for the airbag shutoff area, then found an aux lamps switch. I have 1 switch for those rears and another for 2 front lights on the grille guard.
I put the White Night set up on and also had to modify to fit. Mine are hooked to a switch in the cab and a relay with the backup lights, come on either with the back up lights or if the switch is turned on. If you live in the snow belt as I do DONT BUY THESE LIGHTS! They are not sealed from the back and they do fill up with snow and s**t. I am changing mine to PIAA's as soon as I can.
    BigJake
    BigJake
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
